Old 03-28-08, 02:36 PM   #13 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
Rep Power: 6 MReid is a glorious beacon of light
Re: blue coolant hoses - napa? HELP!
The Earl's beader doesn't work at all on stainless. The better solution is to weld a bead around the tube 1/2" in from the ends. As an alternative, you can drill four holes 90 degrees to each other and 1/2" and screw in four round head ss sheet metal screws #8-3/8" works well. Insert the tube in the rubber hose and ensure the clamp is past the screw heads. It will not come off.
Have fun with your build! - Mark
FFR Daytona Coupe
RCR Gt40 Mk1 in the garage, and underway!
MReid is offline   Reply With Quote
