I swiped the following quote from Mark Reid's build thread in the hopes that we could get a good central repository for hints on fitting from guys like Ron Randall..
Originally Posted by ronrandall This is the first RCR product that has passed threw our doors and let me say I am very impressed to say the least. Mark installed all the mechanics and we will be doing the body fit, prep, paint work and metal plating. The best advise I would offer to any one that is fitting there RCR body to the chassis is to start with the rocker panel first, I like to slot one hole in each panel and use the slot to align the panels, next I slot the spider the same way using the rear clip as a guide and leave a 3/16 gap. Install the front clip the same way. The doors take the longest to get right, I slotted the aluminum mounting point horizontally, this give you easy adjustment of the door up, down, forward and rearward and with the adjustment that Fran has designed into his hinge its make it possible to get 3/16 inch gaps in ALL THE BODY PANELS.
I have not done any edge fitting yet and already the body panels and gaps looks great. All I can say is "Fran if all your bodies fit this way I will work on your product any day!! |
Ron - I'd love to see some pics of where you are talking about the slots in the spider and rockers..
Also - It seems like you dial in everything off of the rear clip. Since the rear clip has a lot of up/down - fore/aft adjustment from the pivot points and the rear mounting tray, I'm curious if you just dialed that in first to center the wheels in the wheel wells...
If Mark or anyone else could add some illustrations, it would sure help many of us that are just now or will be getting to that phase soon...
Thanks!
