| Is there a fuel tank diagram? I want to run two tanks in the side pods. I would have a cross over tube about 1 1/2" that connects both sides but has a small 1 quart or so supply tank that is the lowest point of the fuel system to provide fuel to the pump. If I run a breather tube from both tanks upwards to about the height of the head rest and connect them it will allow air to exit while filling. But what do I use to keep the fumes in and roll over protection?
Does this set up sound like it will work? I have never done side pod tanks and do not know what you guys have set up. Is there some simple diagram or picture to get me started?
thanks, Chip |
