Thread: GTD Sports sold
Old 04-26-08, 03:52 AM   #2 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Re: GTD Sports sold
Well it was in my garage for a while, having the Engine Management/loom installed and setup.
It is a semi-monocoupe that Ray Christopher (Mr GTD himself) designed and built. Ally centre section, spaceframed front and rear.
Runs a 2.0L 16v Turbo motor from a Ford Sierra Cosworth, together with the Sierra's 4x4 MT75 transmission and diffs front and rear. (4WD).
Once I'd wired the motor I drove it all of 10 metres and it started on the button. (good old Weber Marelli ECU...)
It was built moderately light and the body is basically off of a 'JADE' and has been widened to accomodate the wider tub chassis.
That Cossie motor is pretty high though (front NS driveshaft runs through the sump), so visability will be interesting.
I'm not sure what series it could compete in, might be good for Sprints/Hillclimbs subject to ground clearance and once fully sorted, would probably make a fun trackday car.. - Something different anyway.
regards
Paul Thompson
p thompson is offline   Reply With Quote
