Old 04-28-08, 06:49 AM   #4 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17 IanAnderson is a jewel in the rough
Re: Help required removing a UN1
Darren
I believe you will have to remove the Slave Cylinder (Needed removed on the DAX with Rover engine)
But before you do - jump into the car and press the clutch - it may generate enough force to break the "seal" betweent motor and bell housing.
After that it is probably time to do a man handling job from the end of the gearbox to breal the corrosion seal between engine and box Ir try tapping around the bell to engine meating line with a hammer to again break the corrosion seal
IAn
IanAnderson is offline   Reply With Quote
