Originally Posted by flatchat Your location register diameter is too big on your pressure plate -- it could be machined down to fit --as long as it will all fit inside the bell housing
Should look like this --- with a 930 release bearing . |
I just passed through the garage from cleaning up outside and thought the same thing you posted - will it even fit? I measured the stack of parts - pressure plate, clutch, flywheel at 4.5 inches. The bellhousing is barely 3.5 inches from the front to the inside where there are bulkheads and stuff in there - doesn't appear to me that it would even fit in the housing.
