Old 05-05-08, 10:14 PM   #8 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 20 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: Remote Water Pump Block Adaptor for SBF?
Originally Posted by wbmusarra View Post
Looking through the Meziere catalogue, the remote pump can have a single or dual outflow pattern allowing you to hook it up to the block inlets on the motor with the right adapters if you keep the pump in the engine bay.. They also have a setup for the thermostat bypass eliminating the Y that Randy shows on his site.
Looking over their website all I see are Remote Thermostats that do not have a bypass.
Meziere Enterprises
There's got to be a way to keep the coolant circulating in the block until the thermostat opens or you'll end up with hot spots.. It would be better to not use a Thermostat at all than to run without a bypass in my opinion.
If the pump I'm using (50 GPM) turns out to be insufficient - I'll add a second pump to help it out.
Regards - Randy
