Old 6th May 2008, 03:50 PM   #12 (permalink)
Gibbo
GT40: Tornado
Re: Remote Water Pump Block Adaptor for SBF?
As promised some pictures. Although not runing yet I don't intend to fit a thermostat and use Davies Craig controller unit to alter water flow according to engine temp (low temp low flow, high temp high flow).
The pictures are of the modified timing chain cover (modified means taking a hacksaw and dremel to the bits of the cover that only served to hold the pump).
The other picture is of the inlet adaptors. the black ones in the fore ground were the mark 1s, done with only a hand drill and a file. the one i plan to use is the shiney one (holes are perpendicular thanks to a piller drill and the 3/4 inch threads went better).
i was going to paint the new one but the i think i prefer the polished look.
Name:	Timing Chain Cover.jpg
ID:	29430   Click image for larger version
Name:	Water Inlet Adaptors.jpg
6 out of 7 dwarves are not Happy.
Gibbo is offline   Reply With Quote
