Thread: new rear window
Old 05-08-08, 07:12 PM   #1 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
Rep Power: 3 P2164 is on a distinguished road
new rear window
After driving for awhile I found the noise and heat from the rear view window to be a problem so I scribed my old .125 window from the engine side then digitized it and put on my cnc router. Its made of .75 cast acrylic which is very clear, .5 of it protrudes from the engine compartment into the cab the fit its .020 larger than the scribe mark to make a seal into the rubber when inserted. I also pre-drilled holes to use as pilot for the drilling on the cab. The air cleaners are made of .5 lexan and routered to a perfect fit on the throttle bodies. I am interested in marketing these to GT40 owners so if anyone is interested send me a Private message or just give me your comments. Thanks
ID:	29478  Click image for larger version
ID:	29479  Click image for larger version
ID:	29480  Click image for larger version
P2164 is offline   Reply With Quote
