| Re: 48 IDA actuaction arms John,
To run the numbers I need the distance between the two banks of webers, mine is 182mm.
I am assuming the shaft is central to the two banks of webers.
I also need the center height of the weber arms relative to the top of the heat box plate.
The center height of the shaft above the heat box plate and also the dimensions of the T pieces located on the ends of the shaft.
Remember the arms on a standard weber go from -36 degrees (closed) to +36 degrees (open) where 0 degrees is vertical and when viewed from the rear of the engine. They have a crank radius of 30mm.
My arms have the angle different for the two banks and the crank radius is bigger.
Send me the numbers and I will post results.
Andy
__________________ replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...' |
