| Re: DAX40 Return to the Road Thanks guys, I already ordered a gasket set, inc secondary diaphragm so that rebuild guide will be handy.
I checked the float chamber levels today, and found that the secondary adjuster was down so far that it had disengaged from the adjuster nut, so I followed the wet adjustment procedure. I could blip the throttle by opening the secondaries by hand, so there is fuel getting through now, tomorrow, I will take another test run.
Dave
__________________ DAX 302 Installing Alloy Rad |
