Old 05-12-08, 08:12 AM   #2 (permalink)
cribbj's Avatar
cribbj
Missing a few cylinders
GT40: Only the motor & G50, so far
Rep Power: 5 cribbj is a jewel in the rough
Re: leaking turbo gasket
Assuming you're referring to the gasket between the turbo and the exhaust manifold, you must have some very high backpressure in your manifold if you're blowing that gasket!
Perhaps O-Ringing the flange & turbo would be a solution, or consider going to a larger A/R turbine housing?
cribbj is offline   Reply With Quote
