Old 05-12-08, 03:24 PM   #6 (permalink)
cribbj's Avatar
cribbj
Missing a few cylinders
GT40: Only the motor & G50, so far
Rep Power: 5 cribbj is a jewel in the rough
Re: leaking turbo gasket
Hello Lucas, sorry I wasn't referring to a conventional o-ring, but something metallic like you would use to o-ring a head to a block.
Here's some new technology that I understand works very well for a drag race team who are running over 45psi boost on a Japanese motor: Helicoflex. They have o-ringed their head to the block with this gas filled SS o-ring and it works well, and is also reusable because it does not deform permanently after installation, but will retain its original shape.
The A/R ratio I was referring to is illustrated in the photo below. Turbos with a small A/R ratio spool up very quickly, but are also more restrictive to the exhaust system.
cribbj is offline   Reply With Quote
