| Re: 302 engine mounts If you use the rubber bushed engine mounts they will work with Roy's item, but if you upgrade to poly bushed mounts as I did, you may have to re-drill the mounts and dress them down a bit to provide clearance. I know it does not make sense, but that is what I had to do to get my motor down into the chassis.
Brian
__________________ ...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery |
