Old 05-13-08, 12:36 PM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
Ford 302 drivetrain for sale UK
Due to a change of plans, I have my 302 and gearbox for sale. Full spec is
1986 roller block 302 V8
Rebored (30 thou over) and complete rotating assy fully balanced by Mike Huddart.
New pistons, rings, oil pump, water pump, main, big end and cam bearings, Uprated oil pump shaft, All new gaskets (obviously!) standard heads (was going to upgrade at a later date) Weiand dual plane intake manifold, holley 600cfm carb, Mallory distributor.
Renault 30 gearbox, just 5,000 miles, shaft converted to RH shift, already fitted with Renault-Ford driveshaft adaptors, Renault bellhousing, GTD adaptor plate, AP clutch, clutch cover, release arm, release bearing etc
Basically a complete setup ready to drop in. The gearbox is in excellent condition with VERY low mileage, the engine is full assembled and ready to run.
Engine and gearbox are not fitted together for ease of transport. Can assist with loading as have engine crane. May be able to deliver if you have crane other end!
Please feel free to pm, email or call to make me an offer.
Simon
simonjrwinter at hotmail.com
07802 463848
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline   Reply With Quote
