Old 05-15-08, 03:50 PM   #11 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
Smile Re: Rover / Buick 3.5 ltr alloy V8
Originally Posted by Fred W B View Post
Hi Jac
I also expect I will have to reduce the compression ratio, by using the thicker composite head gaskets
Fred W B
No, keep the minimum possible squish distance ( piston to head distance @ TDC ) & lower compression by enlarging either piston dish volume or head chamber volume or if necessary a combo of both. Using thicker than necessary head gaskets increases the risk of detonation even though the comp ratio is lower. Since motor is not assembled yet I would machine piston dish-- dont touch the squish band--- & rebalance if reqd.
Oh, and while the pistons are out cut pressure relief & anti det grooves on the two top ring lands.
Jac Mac,
DIY Mono MkIV,390,J44,15" Turbines.
jac mac is online now   Reply With Quote
