Old 05-15-08, 04:29 PM   #5 (permalink)
Kev Farrington
GT40: KVA/GTD+GTDin p
Rep Power: 2 Kev Farrington is on a distinguished road
Re: Renault transaxle flippable?
Hi Ian,
A quick answer to the questions you started with. The first problem was what oil level to run, what to do about a breather and whether I needed an oil cooler. I had to experiment because nobody else that I know of had done this before. I overdid the oil initially but the box kindly removed what it didnt need via the breather. The breather needs some careful thought and it took a while to get it to work right but it works fine now. I initially ran with an oil cooler and pump but have removed them now with no apparent problem with the use I put the car to, ie road use. Cheers, Kev.
Kev Farrington is offline   Reply With Quote
