Old 05-15-08, 04:54 PM   #6 (permalink)
iank2112's Avatar
iank2112
9 Tenths
GT40: none yet
Rep Power: 17 iank2112 is on a distinguished road
Re: Renault transaxle flippable?
Thanks for the info Kev, I'll keep it in mind.
I am still debating which path I will go down when the time comes, but
a used GTD, or even an unfinished one, is still a possibility. And so many
of those still have Renault transaxles. So, I am always looking into options.
One interesting option is flipping an R21 or similar (anyone running an
R26/7 out of a Lotus Esprit?), and seeing if the 6 spd set up that is sold
through Andy Sheldon/Tornado would be viable. This presents some interesting
possibilites in that you have an inverted box for lower cg, a compact 6 spd
set up (ZF and G50 series 6 spds are pretty long), and if you believe the
numbers, an R21 can handle 300 Nm (221 lbs/ft) - the 6 spd conversion claims
it can handle twice that - 600 Nm (442 lbs/ft) - that's definitely sufficient for
a nicely done 302 stroker.
Of course, if I can duplicate the Renault to Ford bellhousing for an inverted
set up, using a Ford V8 clutch is also a plus.
A few fries short of a Happy Meal
iank2112 is offline   Reply With Quote
