Originally Posted by Lambo It would appear from looking at an exploded view that it is possiable to lock the centre diff with the mechanizm at the rear and so send all the drive up the hollow shaft to the pinion shaft.The rear flange will still turn in sync with the driving shafts. |
Lambo, this sounds correct, but you would need to check that the components are the same strength/size as in the FWD box. The reason I say that is that a FWD box transmits all the torque to 1 axle, so in theory has to be stronger than an AWD which shares the torque between two. I don't know whether that is so in this case, can anyone enlighten us on this?
Dave
