| Re: Upgrades/options and mods to P2125 Brake pad upgrade by Steve with "NEW" pads....Olthoff now has "better" street friendly pads available
ZF T44 look alike cover (specially foundered and machined to replicate T44 but, prim ary reason was to move mounting ears foreward in order to preclude need for mounting spacers) by Pedro and Steve, also cover breather by Olthoff
Dual independantly controlled bulkhead mounted fuel delivery pumps with faux covers (these pumps are fed by a seperate Carter located in the left rear spoonsoon cavity via a swirl pot to insure constant supply) by Olthoff
Inertia switch wired directly to dash fuel pump switch by Steve...battery isolator (ground cut off) by factory
Door handle (strap) idea Lynn Miner..Steve install |
