Old 05-27-08, 04:31 PM   #16 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Re: Upgrades/options and mods to P2125
Chuck,
In my case doors seal well against the rubber w/o the eyebrows and clear the eyebrows when closing and when closed (no contact); doors shut easily and fully with little force (one thing I found is to glue foreward edge of door weatherstrip at base of windshield pillar just before it goes verticle and with this fix door closes much easier). I wanted them for "the look" ( I don't like the plastic) and in case door lips rose up running. Door edges under the eyebrows are protected with 3M. Went with clear coated Al as was difficult to match stripes, felt the paint edges would rub off and like the silver look (matches the other silver accent pieces)
Doors can be adjusted at hinge pionts and at striker. I have had both doors off and on a few times to run side marker wiring..Easy; there is a knurled top pin that runs through top and bottom hinges and through door with a rubber insert top and bottom...Suggest if you align the doors that you keep the pin installed and adjust top and bottom hinges with the striker removed untill door seal correct then install and adjust the striker last.
Steve
steve c is offline   Reply With Quote
