Old 06-01-08, 09:01 AM   #90 (permalink)
Dimi's Avatar
Dimi
GT40: DRB Chassis 68
Rep Power: 5 Dimi will become famous soon enough
Re: Dimi's Build DRB #68
Hi Bobski
The 5.4 feels really great as it is using the stock Ford ECU without all the inhibitors that were programmed into the stock Ford program.
I have the software that allows the Ford ECU's every parameter to be altered or switched off as needed.
So the engine responds exactly as required but runs with the smoothness as per the stock Ford installation.
All the original engine sensors are utilised which keeps the engine running faultlessly without having to use a BEM or unneccessary inputs.
It's been a blast to drive and the power stays full on right through the accelleration in each gear.
Dimi
Dimi is offline   Reply With Quote
