Originally Posted by Vintage64 Update:
Not fixed: turn indicator
Not fixed: rough engine, lots of back firing and idle stalls
What really pisses me off is that they give me the car back without fixing the two most important issues (engine & turn signal).
Thomas |
Thomas,
What is the problem with the turn signal?
I had an issue with mine (2155) where left turn signal would give left rear and right front. Right signal would give right rear and left front.
In addition, there was a problem with the driving lights.
I found the problem in the two plugs that are on the right behind the radiator.
There was a yellow wire going to a yellow/black and a yellow/black going to a yellow. i.e., each of the two wires were in the wrong plug.
I used a small screwdriver to bend down the locking tab on each one, pushed them out and moved them to their correct plug.
Problem solved! Even the driving lights worked after that.
Currently, I'm tweaking the EFI some more and driving it a lot more.
Took some pictures of it last weekend and put them on my website.
Kirby's Detomaso Korner
I also think I'm over the 'crap in the fuel tank' issue. Finally...
Last time I pulled the filter, it had very little of the famous junk in it.
Hope the above helps.
Kirby
