| Re: Which winch ? Eric,
Make or buy some ramp extensions to set the door on. I made approx 4ft extensions and they don't take up alot of room. Quite a hassle to lift the nose of the trailer each time to load and unload plus nessasary tongue weight to offset the car as it enters\exits.
Also, I mounted a simple hand winch (as used on boat trailers) on a small aluminum frame that when needed simply tie straps to floor with existing tie down loops. Easy to store as well. $40 usd
__________________ Tornado TS40, Dart Alum 351\427, 8 Stack EFI
G50\52 w\cooler, cable side shift, Halibrand KO, Hoosiers |
