Originally Posted by Womabt Excellent post Chuck. It could not have come at a better time as i'm currently aligning the body and recognise the issues you've documented - which is comforting. Can i ask - does the roof of your spider rest on the rollbar rear hoop ?
Cheers,
Simon |
Ditto... I'm a good 3 FULL days just in getting the spider to come close to fitting.. The rear clam shell was also cut short on the left side so I will have to build up that edge. Building up edges is a PITB and if not done right, they'll snap right off...
Chuck - I also noted that on the left side, the body lines of the spider do not align or carry the same angles of the door and rear clam shell - Is it that way on yours also?
