Old 06-21-08, 11:13 PM   #11 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
Rep Power: 9 Jim C will become famous soon enough
Re: Red Top batteries - Warning
Malcolm
To load test the alternator I disconnect the ignition.
Crank for a good 30-45 sec.
Connect ign and start.
With a clamp style amp meter you will get a reasonable idea.
On start up amps will be high and volts low.
Run at 1500 rpm as volts go up amps will drop.
If you have an amp meter in the car you wont need test meter.
Jim
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
www.mentalperformance.com.au
Jim C is offline   Reply With Quote
