| Re: Red Top batteries - Warning I too have not had good luck with Optima red top or yellow top batteries. I have been through three. I have gone to a larger alternator and not much improvement.
My first problem is that they were advertised as a great battery for a collectable cars or a car that is driven sparingly or seasonally. I too find them to be very sensitive to charging techniques. With my first battery I was told by the battery rep that the Obtimas don't like a slow charge so "hit it hard" meaning lots of amps. I found this to be WRONG. I then proceeded to ruin my second battery too using his advice-after all he sells them. Yeah right. So they may be a great battery but they are anything but maintaince free.
Then I was told that I needed a charger that has a "gel battery" or "spiral cell" charge setting. So I bought one and that's when I learned that you do not hit these batteries hard, but the damage was already done. I also was told once they go all the way down they never come back the same????
This week I bought a new glass mat gel battery made by Braille Inc. Not cheap but certainly light. 21 lbs and that is 1/2 the weight of the Optima. I bought the carbon fiber case model and we will see how it does. For sure I am going to buy the charger that they sell and recommend. Google their site.
I am going to call their tech line and see how a Battery Tender will work and if it is recommended.
At this point I am thinking maybe I should just get a sealed lead acid maintance free battery for $100 and chuck it in the trash every couple of years.
I will put some dense foam under it to minimize the vibration.
Now I will say my daughter has a Optima Red Top in Jeep Grand Cherokee. It is a daily driver year around and she has been served well even in harse cold weather.
I think the problems begin when they sit around,discharge and the wrong charger settings are used or too small of a alternator. |
