Originally Posted by crash33 It's stuff like this that made me make the statement that an RCR SLC is MAYBE registerable, and maybe not, even though Fran insists that it is registerable. The only way I saw to get it registered in CA would be to put an old engine/trans in it, use the tags from a 1960 something donor car, or try and get an exemption by using alcohol. That's pretty much why I came to this thread. I wanted to know how to go about getting a car like the SLC registered, and if it was even possible. My family has two places in AZ. Maybe the best thing to do, if I ever get an SLC or something of its ilk, would be to just register it in AZ, but I know the 30 day rule, and I can't believe a car like the SLC wouldn't be pulled over frequently just so the leo could have a look see. The AZ plates would probably have to go pretty quick. Then the question is, would it be easier to transfer the vehicle from another state, or do a virgin in CA?
I understand that the rule in CA says that if the year of the vehicle and engine can not be determined, then it is considered a 1960 vehicle. What exactly do they look for to date the vehicle and engine? Just the stampings, or the style/series production of the engine/vehicle? |
You have basically two options to register an SL-C in CA.
1) A used/rebuilt engine, and use the smog equipment required for that year.
There is a way to register a car in this manner without using SB100. The
only problem is you will possibly subjected to a biannual smog test. Depending
on the engine used, it could be easy, it could be tough.
2) Go through the SB100 process, and find an engine that does not have any
manufacturer date codes on it, or a used/rebuilt one that is old enough to
make you smog exempt (1965 and older).
Transaxle, heads and diff are not an issue in either case. At least that's my
understanding
