Old 07-18-08, 06:46 PM   #1 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
351 Windsor help
We are just about at the fire up stage with my build. Here is the problem.We are using the F.A.S.T. ignition system. After installing the crank balancer/spacer with the balance removed(engine is internally balanced), we ran into a problem with the front crank pulley setup. There will be a crank trigger installed and then the pulleys. We can't seem to find one that will mount or match up to the spacer. Spacer is a HiPo Ford piece. Was wondering what we are missing with our search. Everthing that we think will work, is either too small a diameter or the three bolt holes don't match up. Checked with the speed shops for Moroso etc., but without any success. Have had to return each piece that we have ordered. Do we need to look at the marine engines, or is there something that we are missing?? I want a double V belt arrangement to run the alternator and AC. We can't start the bracket fabrication til this is solved.The water pump has been removed for an electric setup, so the alignment is based on the crank pulley placement. The pics I am including are not the best in the world, but should give you an idea of what we are shooting for. Any help would be greatly appreciated.
Name:	Web P1010217.jpg
ID:	31218   Click image for larger version
Name:	Web P1010218.jpg
ID:	31219   Click image for larger version
Name:	Web P1010231.jpg
ID:	31220   Click image for larger version
Name:	Web P1010237.jpg
DRB#5
wbmusarra is offline   Reply With Quote
