Thread: SLC 001 Build
Old 07-20-08, 12:49 AM   #6 (permalink)
P-nut
RCR SL-C
Rep Power: 2 P-nut is on a distinguished road
Re: SLC 001 Build
Hey Rob,
Thanks for the update on the wheels. I may just fab up some quickie spacers to use while assembling the car just so I can avoid buying a "new" set of roller wheels. Anxious to see what you end up with with your car!
Lesson learned: C6 wheels don't work on the SLC! I knew the offsets were different, so it isn't too surprising, but I didn't anticipate caliper fouling problems.
Are you sure there isn't enough droop to allow the car to be raised up an inch or two? Even if the car only has 4" of total travel, it should have 2" of droop, right?
P-nut is offline   Reply With Quote
