Originally Posted by Jim C Where the shift shaft goes into the box and connects to the selector forks I am certain there are 2 coil springs in there that cancel each other out at rest.
You maybe able to increase the tension.
I have an O1E on a rod set up and it centers strongly, maybe your cables are dragging.
Jim |
Jim,
Actually the way the 01E returns is very smart and simple. It does NOt use 2 coil springs. It actually uses only 1 spring for the left/right motion. The shaft itself has a V shaped grove. There is one preloaded spring with a ball point tip on it. It acts perpendicular to the V. The center/rest position is the middle of the V. When you move the stick left the shaft and V moves left and the spring compresses. The spring force acting downward on the V forces the shaft to move back to the center position.
I was debating whether or not to make my own spring here with a higher spring rate, but decided it woudl be easier to make another system with 2 pull springs. The stock spring thingy is about $70-80 so they are not cheap. But they are pretty cool as they are threaded and just screw into the box. Very clean and simple and work great.
Adam
