| Re: low enguagement brake pedal.. why? Yes the rubber lines will make a difference...
Even new ones are subject to expansion..
If you really want a high and tight pedal, look into replacing the lines with steel braided teflon lined AN3 or AN4 hose/fittings.. Also if your car does not have ABS, you can implement 2# Residual Pressure valves in the circuits. These will keep your pedal high and with no penalty.
__________________ Regards - Randy
My build site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
