| Re: vents... This is interesting as I had to replace the terminals feeding the blower switch on the high position and the main feed to the switch, both had excessive current going through them causing them to heat and turn dark brown. I was not aware of any relay involed with the process.
__________________ SPF GT40 MK1
and a bunch of other stuff
Typing is not my bag To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
