| EGLITOM 10 tenths
Join Date: Sep 2007 Location: Germany GT40: RCR40;LR331;G50
| Re: Goodyear vs. Avon Quote:
Originally Posted by evomind thats a good chart....
whats the widest tire we can fit on the rear of the stock SPF rim? | I assume the rear rim width is 10" . Is this correct.
If you check the chart you could check for the tires which are in "measuring rim" size up to 11", because this rim are usually representing the optimal rime size from which you can diviade + - 1 - 1,5" .
I filtered the chart accordingly and came up with this selection. | Brand | Type | OFFICIAL SIZE | Dia wheel | Width | Ratio | Tire Height | TOTAL DIA | TOTAL DIA in mm | Threadwith | Sectionwidth | Measuring Rim | Max RIM | Speedrating | RADIAL | | | | | | | | | | | | | | | | | MICHELIN | TB5R | 285/40-15 | 15 | 285 | 40 | 4,5 | 24,0 | 610,0 | 11,5 | | 10 | 12 | ZR | | | MICHELIN | TB5R | 270/45-15 | 15 | 270 | 45 | 4,7 | 24,4 | 619,0 | 10,9 | | 9 | 10,5 | ZR | | | HOOSIER | R6 | 275/50-15 | 15 | 275 | 50 | 5,3 | 25,5 | 647,7 | 10,0 | 10,8 | 8 | 9,5 | RACETIRE | x | | GOODYEAR | BLUE STREAK | 26,5 x10.0-15 ( cobra) | 15 | | | 5,8 | 26,5 | 673,1 | 10,2 | 12,9 | 10 | 10,5 | RACETIRE | | | AVON | Cr6ZZ | 295/50-15 | 15 | 295 | 50 | 5,8 | 26,6 | 675,6 | 9,9 | 12,2 | 9 | 10 | VR | | | HANKOOK | RH 06 | 295/50-15 | 15 | 295 | 50 | 5,8 | 26,6 | 675,6 | 9,8 | 12,4 | 9,5 | | VR | x | | GOODYEAR | BLUE STREAK | 8,00-15(G7) | 15 | | | 5,9 | 26,8 | 680,7 | 10,3 | 13,2 | 10 | 11,5 | RACETIRE | | | NITTO | NT 555 R | 325/50-R15 | 15 | | | 6,5 | 27,9 | 708,7 | ?? | 13,1 | ?? | 11,5 | VR | | | BF GOODRICH | G Force Drag radial T/A | 325/50-R15 | 15 | | | 6,5 | 27,9 | 708,7 | | 13 | 10 | 12 | ?? | x |
to be sure go for the rim recos of the tire specification.
Also a thing to check is clearance through the whole suspension travel. Especially the wide and big diameter tires like the last three in this list could create some issues on this topic.
TOM
__________________ RCR EUROPE
www.s-performance.de |
