| Re: How far from the cage? Make real sure you make the appropriate adjustments to the height of your shoulder harness mounts when adding the Hans device to the mix.. You can end up with spinal compression if you don't..
__________________ Regards - Randy
My build site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
