transaxle on audi v8 engine
Hi!
Im working on a project, not gt40 but a ford escort mk2.
I need to know witch transaxle gearboxes fits the 3.6l Audi v8 engine from 1990:huh:
just bellhousing pattern needs to fit cause im cutting the bellhousing and fitting it on a Bmw m3 box:tongue3:
Thanx guys,
I'm using the same engine and all the sources I've found say the popular 016 transaxle (from the Audi 5000) mates right up except for one bolt hole, but it's not one of the larger, more loaded bolts. I do not know about throw out bearing / clutch alignment though...
Audi 5000 is audi 100 c3 in europe rigth?
and witch models came with the 016 gearbox?
Sorry, I don't know Audi models that well, especially European models. Make sure you get a 2WD gearbox, not 4WD because supposedly modifying the 4WD to work as a 2WD is not as strong as the 2WD gearbox.
Hi, I am currently design a frame for a 4.2ltr Audi V8, has anyone got the dimensions for the bottom end width, i.e. distance between engine mounst, kindest regards Rich
you can use many Gearboxes ... 016, 01X, 01E, 0A2 ... all the same pattern
http://img411.imageshack.us/i/audi100gboxmanual007.jpg/http://img411.imageshack.us/i/audi100gboxmanual007.jpg
http://img651.imageshack.us/i/audi100gboxmanual008.jpg/http://img411.imageshack.us/i/audi100gboxmanual008.jpg
