Old 17th February 2011, 09:47 AM   #1 (permalink)
Geoff Deakin
2 Tenths
GT40: KVA C-Type Mk I
Oil pressure, oil temperature and water temperature sender units question?
Another question to those that have done all this before:
I'm fitting Smiths mechanical OPG, OTG and WTG sender units to a 302.
I'm very short of space re the oil pressure sender - It needs to fit in between and behind the air con compressor and the oil filter, together with an oil pressure warning light - Almost impossible?
Ditto the oil temperature and water temperature senders.
I have a sandwich plate and oil cooler fitted - Wondered about fitting an adaptor to take the oil temperature sender, into one of the hoses?
Could I fit something similar into one of the coolant hoses?
Thanks in advance!
Incidentially, to all those who have helped me with this winter rebuild - If I haven't thanked you so far, THANKS VERY MUCH - I would be lost without the knowlege on the forum.
Cheers,
Geoff.
At last!
KVA - 302 - Renault 'box
Geoff Deakin is offline   Reply With Quote
