Originally Posted by Geoff Deakin I'm very short of space re the oil pressure sender - It needs to fit in between and behind the air con compressor and the oil filter, together with an oil pressure warning light - Almost impossible?
Ditto the oil temperature and water temperature senders. |
I have taken a -4 hose from the block for my pressure sender and also warning light. I have the water sender in the intake manifold and will be putting the oil temp in the sump.
Brett
