My Avons are very sticky and do pick up every rock on the road. That said, a little foam glued to the underside of the wheel wells stop the rocks from causing damage.
Kevin
What kind of mileage do you get out of a set - street driving?
Kevin
How are the Avons in the rain? I have heard they are not nearly as good as street tires.
What do you set the tire pressure at?
What does a set of Avons cost?
Brian,
Looks great! What size DOT Avons are you using. I've been eye'n a set for mine.
295's on the rear, 215's on the front.
Brian
Follow-up
An official at Superformance confirmed that Mr. Jack Dunn's wide body shown here: www.gt40spf.com is an extra wide body clip.
I love Jack's ride and it was an inspiration that helped me overcome the natural tendency I harbored to not write that check for one of my very own. Way to go Jack!
Rob
nice stance, it just fits
I am quite certain that Superformance has molds for three separate tail clips. The standard size is most typical and is included in the base price. There are two wider versions. The subject becomes unnecessarily confusing because of the names they assigned to them. There is no name for the standard, the slightly wider version is called narrow body, which most would assume is the standard - but no - it's the smaller of the two wide bodies available...
