Old 30th January 2012, 06:28 PM   #12 (permalink)
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: Which battery to use?
Question:
Does it really matter where the battery is located? I have about 9-10 feet of #1 wire from the front of the car to the starter(think it is #1, diameter is .5"). I believe it is causing a voltage drop that is causing my ring gear, starter gear, and alternator problems. If I move it to the rear with 2-4 feet of cable, or even 4-6feet from mid engine location, will that give a better response and less work on the electrical system?? I came across a 1000 CCA battery at Advance Auto for $104 today. It has the screw terminals on the front like an Optima and is 10"x6"x7". It comes with a 3 year warranty.
DRB#5
351W/392 DIS TWM F. I. 930 Porsche LSD
wbmusarra is offline   Reply With Quote
