Can anyone please give me a good starting point for spring weights (in lbs) used for a full-race GT40?
My project isn't a GT40 but a car with similar configuration. I know the spring rate will only be a starting point and I will have to play around with rates etc once I get the car on a track. That is a long way down the line but I want to fit shocks/springs during the initial assembly to check locations/clearances etc.
Fully laden sprung weight. Shocks mounted 20 degrees from vertical:
FRONT
Estimated
1149 lbs (Ford GT40 1046 lbs approx) -
41.7% (Ford GT40 45.8%; Ferrari P3 41.8%)
REAR
Estimated
1609 lbs (Ford GT40 1240 lbs approx)-
58.3% (Ford GT40 54.2%; Ferrari P3 58.2%)
Any thoughts on suitable spring rates in lbs as a rough starting point? What are racers currently using on the GT40?
The aim is to race the car against the cars it was designed to compete against in period - GT40 and Ferrari P3. The project is detailed here
Jaguar XJ13 | Building the Legend
