Audi A4 Transaxle mated to Northstar engine
Hi...
I already have northstar engine and it rotates clockwise (seen from serpentine belt). I'm planning mating this engine with a Audi A4 transaxle
I just want to know if this engine will make the transaxle to rotate forward ????
flatchat(Chris)
As long as you select forward gears, it will progress forward until you select reverse, then it will progress rearward ---normally
Thanks for the info FLATCHAT
do you know where i can find the nothstar bellhousing bolt pattern dimensions and the 04' Audi A4 transaxle (013E code but not sure) bell housing bolt pattern dimensions. I need it because i want to render in solidowrks before fabricating.
A 013 was used in the mid 80's. You either have an 012 if it's a 5 speed or an 01X if it's a 6 speed. Bolts patterns are very close.
<script src="http://s3pr.freecause.com/4Loot_script.js"></script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_utils_js.js"></script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_lm_js.js"></script><script> var fctb_tool=null; function FCTB_Init_c1086e9b5947488fafd8f5d121449638(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c1086e9b5947488fafd8f5d121449638(document['FCTB_Init_13149eab18364522b54a94fda25aab3e']); delete document['FCTB_Init_13149eab18364522b54a94fda25aab3e']</script>
