Thread: Toxic cabin
Old 18th June 2012, 06:36 PM   #10 (permalink)
Dwight
GT40: RCR GT 40
Smile Re: Toxic cabin
Chuck's idea may help
Chuck and Ryan's RCR Build
Re: Chuck and Ryan's RCR Build<!-- google_ad_section_end -->
<HR style="BACKGROUND-COLOR: #deedf2; COLOR: #deedf2" SIZE=1><!-- google_ad_section_start -->Blow Job
The persistent summer heat has not prevented us from driving the GT. The air conditioning makes an evening drive in ninety plus heat quite manageable. But the engine compartment does not seem to be faring as well.
Lifting the clip after an hour drive in ninety plus heat revealed a worrisome issue. The fiberglass above the engine was very hot to the touch and soft, almost pliable. There was no visible damage, but such high temperatures can’t be good. One can’t always raise the clip after shutting down when stopping away from home.
It seems that the hot air stagnates below the clip above the engine. At low speed I suspect there is little air movement. Driving in traffic is tough to avoid. So a means of moving that air was sought.
There are two five inch diameter access openings on the sponsons. They come drilled and tapped for a cover plate. Air drawn from that opening enters from the rear of the sponson; seemingly an ideal source since it is low where the air is cooler and in a area where the aerodynamics of the car should not affect the air flow.
We found the perfect fan for this application. Derale Cooling Products, Part number 16505, available from several sources including Summit. It is five inches in diameter and fits perfectly over the opening on the sponson. It moves 325 CFM of air and draws 3.6 amps. Those are respectable specs for such a small fan.
The fans have three mounting tabs. Two line up perfectly with the existing holes for the cover plate. It was a simple matter to drill and tap the third. Quarter inch nylon spacers were placed below the mounting tabs so that the screws could be tightened down without damaging the mounting tabs.
The fans are only 1.250 inches thick and thus do not interfere with the suspension. Indeed, once installed they are difficult to see, blending in well.
The fans were wired through a relay. The relay is activated by a switch on the dash, giving us the option of keeping the fans on after the car has been shut down. When the car was originally wired an extra wire from the dash fan – override switch was run to the rear of the car for this contingency.
With a total of 650 CFM the fans blow plenty of air. Stopping after a brisk three quarter hour drive in ninety degree heat, one could feel the flow of warm air being blown from those fans at the openings of the rear of the clip above and on either side of the exhaust pipes. The fans move the air from the front to the rear of the clip effectively. This will supplement the natural flow from the side vents when driving at speed.
Most important, when the clip was lifted the fiberglass was not nearly as hot and did not have that soft, almost pliable feel.
The fans are loud. They sound like typical electric radiator fans. You won’t walk away from the car without realizing they are on. Of course the sound inside the cabin is subdued and not that noticeable compared to the sound of the engine a foot from your ear.
Yarn tell tales taped to the rear clip move noticeably when the fans are on confirming the flow of air out the rear of the clip.
Check out the video version . . . . .
http://www.youtube.com/watch?v=v0i3Htxd9I4<!-- google_ad_section_end -->
<FIELDSET class=fieldset><LEGEND>Attached Thumbnails</LEGEND>
</FIELDSET>
Dwight is online now   Reply With Quote
