Hi all
I've fitted the radiator to my car today and am looking at how to fix the fans to the radiator. It seems there are 4 brackets that fit to the corners of the fan and then a plastic threaded tie seems to pass through the radiator to the brackets and are then secured using a cap.
What I want to check is how the plastic ties pass through the radiator. Do you push them through the fins in the radiator as there isn't enough room for them to pass through without bending the fins in the radiator.
As always any advice always appreciated
