"Vigilante 6.0 Vengeance" project
Jackal
CURRENTLY BANNED
Yes, DQS is an 01E.
I posted previously (about the Skoda boxes rather than the Audi but the details still stand).
01E DQS Manufactured 04/01-01/02
01E ELQ Manufactured 04/01-01/02
01E FRF Manufactured 01/02-
Gearbox ratios (DQS/ELQ/FRF all the same)
Final 31:8 = 3.875
1st: 28:8 = 3.5
2nd: 34:18 = 1.889
3rd: 32:26 = 1.231
4th: 27:31 = 0.871
5th: 26:39 = 0.667
6th: 23:41 = 0.561
Rev: 38:11 = 3.455
thanx David.
I think I should go for it, in the meantime I'm fighting to get a refund.
thx again
cheers
Jackal
Jackal
CURRENTLY BANNED
Well.... I decided to go and look for the pot of Gold at the end of the rainbow ..... sure as hell will be easier than getting a refund from Woodbrook Spares! :laugh:
Photo taken today at Theewaterskloof dam on my way to Villiersdorp.
Jackal
CURRENTLY BANNED
Starting to get the bonnet/vents/nose area close to what I want. The bottom front vents I have changed a bit too but not quite there yet.
Jackal
CURRENTLY BANNED
So pushed the fat lady out of the garage to have a look at it. It is getting there but even at this stage, especially when I think of the doors and recesses, I get my doubts sometimes! When I looked at it outside though it's all worthwhile.
We worked on the nose again, the bottom front vents STILL needs work. Where the bonnet and the winscreen meets also needs to be finished. Side vents needs alot of work on the insides etc. etc. etc. etc. :stunned:
Jackal
CURRENTLY BANNED
Thanx Ian.
Honestly, I have underestimated the amount of time it takes! People ask me "when is the due date" for pulling the mold and the body..... My answer is; "December 2011" .... :)
Jackal
CURRENTLY BANNED
Hi Doug,
Ground clearance is 150mm and overall roof height +/- 1120mm, the frame on wheels is about 190mmm high, so looking at the pic visualize it as 190mm lower.
What do you think of 150mm ground clearance? Too much?
Jackal
150mm = 5.875 " may be a bit high but is probably good for road use especially if they are a bit "rough". 4.5" = 115mm is a bit more "exotic" but may be a hassle. For the track you could probably drop down to 4" = 100mm. I think most the GT40 guys around here are at 4.5 -5.5" and keep an eye out for speed bumps!
--- Doug
Since you are doing a custom chassis you can tuck up the tender pieces and still keep the door sills low for the stance you want.
--- Doug
Jackal
CURRENTLY BANNED
yes. I might drop it to 120 mm, then my roof to ground will be 1100 which I think will be more in line. As far as speed bumps..... I was thinking of pneumatic lifter in the front, which should help.
Jackal
CURRENTLY BANNED
I seem to have a problem. The Audi RS4 engine has direct injection and so far I cannot get aECU that will work with it. Furthermore someone told me that I will not be able to set the car up with the existing ECU because of the many sensors involved. Apparently I would even need the RS4 complete dash and also awd etc. etc. etc.
I've been told that I should buy external injectors, modified manifold, have custom fuel rails built and use a aftermarket ECU. The whole story costing a small fortune.
Does anyone have alternative ideas or know of an aftermarket ECU that will work with direct injection engines?
Jackal
CURRENTLY BANNED
Spoke to a guy who says he is 90% sure they could decode the standard ECU. Should know for sure by tomorrow or so. Also found a Dutch company call Kronenburg who sells a complete package, fuel rails, throttle bodies, ecu, etc etc AND gain 80 bhp...... still waiting for a quote from them but I believe it will be to rich for my blood.
I would be tempted to wait.
Everyone is going to GDI, it's not going to be long before the aftermarket have caught up.
If all else fails you can ignore the GDI and run conventional injectors etc. Ok so you'd probably have to make up a custom manifold (or drill/weld in injector fittings) but still likely to be far cheaper than a GDI type ECU would be now.
Jackal
CURRENTLY BANNED
hehehe, sorry mate we call gasoline, petrol over here! so you reckon aftermarket ecu's will catch up soon. I hope so. I do have quite a bit of time before actual startup. Just typically me not finishing one thing (the body) before jumping to bits and pieces (engine, gearbox, shafts, hubs already bought and now worrying about the mapping and fuel management when I'm still miles away!
So do we! Doesn't stop other people calling it Gasoline! :)
Depends how long we're talking before you get to *needing* the engine to be running but I honestly think that we're at the stage where give it a few years and it'll be *far* more common for aftermarket ECU's to support it. They can't not!
