SL-C 002 build Bob DeNyse
bob d
I have had so many inquiries about my car I have decided to put up as many pictures to detail what has been done to it. I must first tell everyone I bought the car built, it was a bad job for a lot of it and I have re-built most of it. I cannot tell you what came with the kit, how it was to be assembled since I never got an assembly manual, or what parts came with the kit and what was fabricated by Ernie the original builder. I do know he has done a lot of items himself for parts of the car that as far as I know did not come with it. This is why I am going to put up a lot of pictures so people can see what has been done. If anyone has any questions I will try to shoot more pictures and give as much detail as possible. I will say this, Fran has been very helpful with this car since he knew what problems I inherited.
bob d
Here are more pictures
bob d
Here are the last set of pictures
bob d
I have placed as many pictures as I can for the various items, I am sure that not all these pictures are self explanatory, if there is any questions please highlight the picture and I can try to explain what that is and what we did, I am trying to help all you guys assembling your car and try to shortcut any learning curve. I am not saying this is how to do any of this but it is a way we found to do it, and I am sure there are a lot of better ways some of you have accomplished for the same issue, and good luck
Fran - was that a engineering decision (the hood needs to be secure) and/or the hood wouldn't jive well with future changes re: splitters, venting, cooling ducts etc. or...
So the front is secured and doesn't open or is it a lift off sorts? Im just curious about accesability for suspension adjustments or other maintenance.
i assume this is the same car where little support was offered from the off on the development and now spun to be the original builders fault.
bob d
The hood has two holes for the pins to secure the hood once down and in place. You can still have the hood swivel and pin to secure it, I think this is a good way to go still. It makes it easier to open the hood and not have to find a place to put it and risk scratching it. I will try to post a picture so you can see what I am talking about. I think it is probably the same hole and pin set up you have without the swivel option. Is that what was designed originally I don't know maybe Fran can input about the additional pin securing the hood along with the swivel.
