Dwight
RCR GT 40 Gulf Livery 347 Eight Stack injection
worked on our trailer today but I did take time to pull one of the fuel gauges out of the dash.
one pair of wires are yellow with black or red tracers. They are wired to the shielded cable to the sending unit (black and white wires). The other wires from the gauge are red, black and white. He has the red hooked to the ignition switch, the black to ground and the white to the dash light circuit on the light switch.
Does anyone have a wiring diagram for the RCR gauges? That would help a lot.
There is no color code of the wires under the dash. I have to trace each one and sometimes it will change color two or three times.
I could use a few of the two conductor connector for the gauges. A lot of the wires are twisted and taped with less than an inch of wire out of the connector.
I would like the use the factory connectors if I can find them. If I had the pins I could re-pin the connector with new wire.
Dwight
Dwight
