This isn't about who has done well. This is about what is your passion. When you login to GT40s.com, are you passionate about a GT40 topic? Are you here to seek help regarding a technical question you are having? Are you here to provide technical advice to others who also share a passion for GT40s and are in need of help? Are you here to see pictures and videos of other member's GT40s and share in their love for these cars? Are you here to learn about events past and upcoming related to GT40s?
Or... did you wake up this morning and the first thing you did was to login to the politics thread all fired up to come back with some witty retort to a worthless political argument that you are engaged in a heated debate over with someone else who does not share your political view? If this is the answer then I submit you need to check your priorities and stop wasting your life away. Most of you are older than dirt and should already be aware of this.
Paragraph 1---yes, I do and have done all of those things.
Paragraph 2---no, I logged in here at work (for which, BTW, I am thankful to those who have reduced the prevalence of vulgarity because prior to today I could not even log on to GT40s.com at work...blocked by the firewall administrators for inappropriate language. I can now connect with GT40s.com at work, where it was "banned" before). Thanks, folks!
...and as for being older than dirt...well, I use to say I was, but a friend challenged me on that and said that although I could not claim to be older than dirt, he had done the research and said that I am definitely older than aluminum foil. That's the only claim I make now regarding my age.
Doug
