Southern GT #48
Ed McClements
I am delighted to say that I have just been to collect Southern GT chassis #48 from Mick and the team, together with a pre-cut aluminium panel set, wishbones and fasteners. Doesn't sound like much, but I'm sure it'll keep me out of mischief for a while.
Collecting chassis in a LWB Merc Sprinter van (just fits perfectly!)
Safely back home after a 600-mile round trip
Chassis with its stablemates
The build will take as long as it takes, with a full-time job, two children at school (one of whom is still in primary school...) and the inevitable other demands on my limited free time. The plan is to build a car with the look & feel of a 64/65 car, 289 or 302 depending on what becomes available and a UN1/013 (which I already bought, and which is currently with Chris Cole for a refresh and high 5th gear install)
Mike Pass
Looks like it’s time to get an air rivet gun - unless you want arms like Popeye!
With the high top gear maybe think about a stroker kit. Anyway good luck and enjoy your build.
Nice one Eddy now the fun begins.
Mikes right, if you have not got one, I have an air rivet gun you are welcome to borrow.
Finished with that stage.
Thank God!
Ed McClements
Thank God!
Hi Bob
Thanks for the offer, but I already ordered an air rivet gun. Last car I built I did all the rivetting by hand and you soon get hacked off with the jolt to your wrists as the inner nail shears off.
Some pics from that build...15 years ago!
holes cut with an adjustable hole cutter
of this design
and finished with snips.
Toyota Corolla twin-cam engine
SVA!
Barbon Hillclimb 2006 (note to Mark Boyers....that's Matthew in the photo!)
Good luck with the fun, the stress, the uncertainty, the questions, the “what the Hell”, the should I shouldn’t I, the “if only” and finally “yep I did it my way”. There are some really special people here that you already know who are a real comfort when stuck at a crossroads not knowing which way to turn.....
Best of luck
Mark
Ed McClements
Hi Bob
Thanks for the offer - I sent a reply at the weekend, but it's stuck in limbo awaiting moderator approval because it contains links to a Flickr album.
BTW, I bought my first Kit Car magazine in 1982(-ish) with a replica Porsche 718 RSK on the cover, and it wouldn't have been many years later when I became aware of some beautiful replicas of a classic, pale blue French 1920 race car. You are that Bob J, aren't you?
Cheers,
Eddy
Thank God!
Ed McClements
Nothing to report yet! Have been buying rivets...2000-odd sealed end 4mm rivets in a couple of different grip lengths
A pack of Presto 4.1mm drills (these are great - have a split-point tip which means they self-centre without a centre-punch mark)
and a fan-spacer tool for laying-out the rivets
Also been sorting through the bewildering array of ally panels trying to work out what goes where
Well....I say bewildering, but in fact it was pretty easy to work out. Mind you, I've been studying everyone's build logs on here for years - so much so that I think I have a 3D model of a GT40 in my head.
I think I'm going to need more Clecos....if anyone has progressed beyond panelling and would like to rent me a load of 4mm Clecos for a few months I'd like to hear from them.
Ed McClements
Laying-out and drilling panelling. Using 50mm centres for the rivets....is this too close?
Ed McClements
The stack of panels which have been trimmed to size, drilled & deburred and set aside for later use is growing nicely. I collected my rebuilt UN1-013 from Chris Cole a few weeks ago:-
and sourced a filthy old 1972 (?) 302 block, crank, heads, rods & pistons. At the time I bought it, the heads were off and the rest of the motor was still assembled, but a mate collected it from the seller and, before strapping it to a pallet and sending it to me he insisted on tearing it down "out of morbid curiosity" (his words).
Bores are still at 4" or thereabouts so not been bored yet. The crank has me scratching my head - the main bearings and rod journals measure (I only have metric micrometers, so both mm and inch sizes are quoted):-
Main - 53.17mm = 2.093"
Rod journal - 56.61mm = 2.228"
That looks to me like the crank has previously been ground undersize, but will it take another grind, and are bearings available?
The aim for this motor is very modest - standard throw crank, 306ci by the time it's rebored, Comp Cams 268h, best ally heads I can stretch the budget to and a 600CFM 4-barrel carb. I'll be happy with 300bhp, ecstatic with 320!
Mike Pass
D2OE block is indeed 1972 from a Ford Fairlane or Torino. As it is pre 1975 the emissions requirement for IVA is “no visible smoke.”
From SBF book by George Reid
Standard main journal 2.2486”
Standard rod journal 2.1232”
Standard cylinder bore is 4.000”
Ed McClements
Mike - that's great, thanks. In that case what I think I have is:-
Standard main My crank difference
2.2486 2.2287 0.0199 (-0.020")
Standard rod My crank difference
journal
2.1232 2.0933 0.0299 (-0.030")
ie. mains at 020 under and rod journal at 030 under. Maybe OK for a low-power build, but I need to be looking for a replacement crank.
Mike Pass
If you want a copy of the article with all the basic info on the SBF that I wrote for the club magazine send me a Private Message via this forum with your email address and I will email you a copy.
