2/18/18 Moved brake lines outside tunnel, so if for any reason I had to move stuff around later, I would not need to re-bleed clutch and brakes. Drilled holes in front driver chassis and used provided hardline. Ran rubber fuel hose over brake lines to prevent rubbing on chassis. Testing gas tank for leaks- should have done this day 1. But as front clip comes off a dozen times in a build, no time like the present. With tank out, it let me solder crimped weatherpack connectors for added security. They ripped off as I was sliding tank out.
Held fine for usual usage, not so good as the connector got hooked on the tunnel and I yanked out the tank. Mounted coolant tank over oil tank. Thin aluminum brackets will need to be changed or added to as I do not want wobble. I bought a fancy seam sealer and it was junk.
3M Products Brushable Seam Sealer 08656 - Free Shipping on Orders Over $99 at Summit Racing
Switched to metal caulk from HD. Love the color, and if I had skills, it would look amazing. Looks good enough. Race car.
Up next:
1. Build oil system, need -16 180 for filter. Catch can? Breather? Vac reg?
2. Trim panels for fuel system to clear engine mount.
3. Parking brake routing, clips to chassis. Need to decide if I will keep my current location of bracket.
4. Clutch line and fitting size. Looks -3AN
5. Need horns -ordered from Speedway $25
6. Start heater mounting
7. Tillett B5? I want to sit in them and see how they compare to factory seat.
8. Relocate transaxle locator rod ends. Cheap swedged tubes makes me think I can change locations of rods to allow more room for exhaust to come through.
9. Trim heat shield away from AC compressor. If it loosens, bad things could happen.
Here are the thin mounts. Can go steel or thicker aluminum. Easy one.
Brake lines exiting driver side frame rail. Plenty of room to just clip outside rail, but exposed lines make me nervous.
Excuse the mess. New brake routing.
Will need H's help doing the splitter mod. Dropping on the spider and sill panels to get him the car. I lack the skills to execute this task without ruining several parts.
